OzzzieMike
Aug 12, 2018Apprentice
Orbi Has Locked Me Out?
I just wanted to glance at a couple of things in my Orbi app on my iPhone, and I was surprised, when I launched the app, that I needed to log in. When I tapped on fingerprint scan login option, it s...
- Aug 12, 2018
A factory reset using the pinhole on the back of the router will reset the password to the defaults. Press in and hold until the power LED goes from green to flashing amber. Try the defaults prior to resetting: admin/password.
st_shaw
Aug 12, 2018Master
OzzzieMike
Thanks for the quick reply!
I'll try resetting via the pin hole tomorrow, as I don't want to run the risk of being without a web connection today/tonite.
(BTW...I know the admin/password won't work, as I tried that first).
