OzzzieMike's avatar
OzzzieMike
Apprentice
Aug 12, 2018
Orbi Has Locked Me Out?
I just wanted to glance at a couple of things in my Orbi app on my iPhone, and I was surprised, when I launched the app, that I needed to log in.  When I tapped on fingerprint scan login option, it s...
  • st_shaw's avatar
    Aug 12, 2018
    A factory reset using the pinhole on the back of the router will reset the password to the defaults. Press in and hold until the power LED goes from green to flashing amber.  Try the defaults prior to resetting:  admin/password.
