Trajectory
Jul 18, 2017Aspirant
Orbi Help default gateway password and username Model: RBS50
So I am trying to connect to my default gateway192.168...etc by typing it into my browser search bar and when I do it brings up the little login box of username and password. I am pretty sure the or...
Trajectory
Jul 19, 2017Aspirant
I am able to provide more info on my wifi router system. The Orbi router consists of 3 different ones around the house and a little rectangle box one.
- TrajectoryJul 19, 2017Aspirant
I have just tried the other 2 router's serial numbers and i can confirm they do NOT work
- DarrenMJul 20, 2017Sr. NETGEAR Moderator
Hello Trajectory
Sounds like the default password was changed the only way to get it back to default is to factory reset the unit.
DarrenM
