Trajectory
Jul 18, 2017Aspirant
Orbi Help default gateway password and username Model: RBS50
So I am trying to connect to my default gateway192.168...etc by typing it into my browser search bar and when I do it brings up the little login box of username and password. I am pretty sure the or...
Trajectory
Jul 19, 2017Aspirant
I have just tried the other 2 router's serial numbers and i can confirm they do NOT work
DarrenM
Jul 20, 2017Sr. NETGEAR Moderator
Hello Trajectory
Sounds like the default password was changed the only way to get it back to default is to factory reset the unit.
DarrenM
