ProphetSix
Feb 27, 2017Aspirant
Orbi hidden unsecure on 2.4GHz/5GHz
Thought I would check here before reporting a possible security issue. I'm using inSSIDer and Acrylic to check on the performance of my new Orbi system, when I noticed something very strange. First, ...
thedak
Feb 27, 2017Apprentice
I looked with Acrylic Professional and I see two [hidden] SSIDs with MAC addresses that match my system (cept for the last hex pair). one on 2.4 and one on 5 GHz. Both are listed as WPA2 and both have no WPS. So they both rate a high security rating in Acrylic.
ProphetSix
I don't have Acrylic Pro, but I see two hidden, 2.4 and 5. It shows that they both have WPA2 up, but also have WPS (a no no) enabled. Now if I fire up inSSIDer...no WPA...wide open...and the last six characters of the MAC address on the 5.0 backhaul and this strange 2.4 transmission. Not liking any of this. Screams of holes in the security of Orbi. And I still don't understand the 2.4 transmission, I have the radio off! Just for giggles I also turned of the 5.0 radio to see if the backhaul stayed up...it didn't. By the way, yes, I'm on the lastest firmware. I've rebooted and factory reset.
