lbobins
Sep 10, 2019Follower
Orbi, HIK CCTV and EE Hub
I’m trying to help a neighbour who is having issues with their WiFi.
So the story is, the EE hub seems to lock up frequently and prevents them using WIFI calling, we live in a sleepy village with a lot of old buildings so people depend on this. The hope was to use the EE hub as a router and Orbi as access points to eliminate the (suspected) WiFi issue.
They have an analogue HIK NVR which has two cameras wired to ballons (Camera 1 and 2) and two cameras wired to a POE injector with one cable going to the EE hub and another cable to the NVR for the internet connection ( and assuming camera 3 and 4 data). At the minute the NVR has a fixed IP (220) and needs three ports opening 80, 8000, 545 which I have configured in the EE Hub and they can view the cameras whilst connected to the EE hub network. My problem is when we connect Orbi up and try to access the CCTV through the Orbi WiFi, I’m unable to see the HIK NVR to open the ports and also unsure of the correct settings to make this possible.
Do I need to modify wiring to connect the NVR to the Orbi router? Am I best using the Orbi as a router or access point and switch the EE Hub’s WiFi off? I’ve read about DMZ but unsure if this is any use and what it does?
1 Reply
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeYes if you have a primary router already in front of the Orbi RBR, then it's recommended to configure the Orbi system for AP mode. ALL wifi on the router in front of the Orbi needs to be fully disabled or turned OFF.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
