foleyconkright
Jun 03, 2018Aspirant
Orbi home network settings deleted
A few days ago our AT&T DSL cables got cut by a lawn crew. We have gotten it repaired but since then, all our Orbi home network settings are wiped out. I've rebooted the Orbi. Is there a way to ge...
foleyconkright
Thanks -
It's an ARRIS NVG599. It does have a built-in router.
We have ISP back. The Orbi is connected via ethernet to the ATT modem.
In my available networks list, there is a generic looking Orbi available - I tried joining it with my old password, but it fails. Could that be my Orbi with a default password?
Jun 03, 2018Guru - Experienced User
I presume the Arris maybe using 192.168.1.1 and this conflicts with what NG uses for there router products however most NG routers auto re-assign an new IP address pool, so it may have moved to 10.#.#.# or something differnet that .1.1..
You can try using default admin and password and see. Try the recovery pw method to see if it will recover. If you can't get in you may need to factory reset and setup from scratch.
I recommend doing of these:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
