sirenoftitan
Feb 19, 2020Follower
Orbi Home Network Vanishing from Windows 10 Wifi List
I have been experience an ongoing issue since installing my orbi system just over 3 months ago. The issue is that the orbi network periodically vanishes from my desktop list of available networks. ...
Feb 20, 2020Guru - Experienced User
What is the Mfr and model# of the WiFi adapter in the PC?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Displaying attached devices, accurately detecting internet status all currently working in v2.5.1.8
sirenoftitan wrote:I have been experience an ongoing issue since installing my orbi system just over 3 months ago.
The issue is that the orbi network periodically vanishes from my desktop list of available networks. This doesnt appear to be a proximity or coverage issue as I have my macbook and iphone on the desk next to my desktop and both remain on the network.
There doesnt appear to be anything I can do to reliably make the network reappear. I have tried resetting the desktop, resetting the network, deleting/updating the driver for the wifi receiver... none of this has a reliable effect. It seems to simply reappear randomly, but my hope is that there is an underlying cause that someone will be able to point me towards. Other networks remain visiable and available, but my own network is missing.
Would anyone be able to point me in the right direction for diagnosing this issue?
