Dtatewv
Apr 23, 2020Aspirant
Orbi Home Selection
I apologize in advance but after trying to read through all the documentation I am more confused then I was before I started. I currently have a RBR40 with 9 satellites connected. The satellites...
Dtatewv
My setup
Fiber to the home plugged into a Meraki FW, 300 Mbps up/down service.
Meraki as the FW, connected to an RBR40 running V2.3.5.32, (qty 3) RBS20 running version V.2.3.5.30, (qty 6) RBW30 running V.2.3.5.6
RBR in Bridge mode.
So, if I understand your topology, you are running an AX and an AC network. Are you getting two separate IP’s from the Service Provider?
Apr 23, 2020Guru - Experienced User
Interesting.
Techincally your in AP Mode. Orbi doesn't have a bridge mode.
Yes I am.
