Rikerrock's avatar
May 02, 2019
Orbi home system and VPN
Anyone know how to get the orbi to work with one of these VPN services?  Expressvpn, nordvpn, notspotvpn etc?
If it wont work with these, what do I need for it to work?  Another router or??  OR is the built in vpn do the same thing?
Thanks.
1 Reply
  • plemans's avatar
    Most of these vpn's have an option to install to your computer/phone/tablet. As far as I know, the only vpn that is supported is openvpn.
    You can buy a different router to install as primary and set ORbi as AP mode.  Thats about the only option I know for a router based vpn other than openvpn.
