amaraa
Oct 08, 2018Aspirant
Orbi Home WiFi System 2 pack
Does Orbi support below:
Mobile App
Bluetooth Onboarding
Location Assistant
Speedtest
Device List
Easy Guest Wi-Fi Sharing
Network Scanning
Router-based Antivirus
Firewall Security ...
Oct 08, 2018Guru - Experienced User
I don't believe the Orbi doesn't support some of the features you listed,
Location Assistant
Network Scanning
QoS (By Device)
QoS (By Application)
Device Activity Report
Automatic switchover without interruption
For specs, review here for each model:
amaraa
Dec 06, 2018Aspirant
Good day.
We have question for RBK50 .
If we puchase your product, Will a configuration of special feature run?
Do you have the regional restriction in special features?
- FURRYe38Dec 07, 2018Guru - Experienced User
What special feature are you looking to run? Orbi can do different things.
Language is only for the UI for different languages that are supported by NG.
