jkimbro's avatar
jkimbro
Tutor
Jan 19, 2020
Orbi hook ups
Hey all,,, I'm real close to pulling the trigger to switch over to an Orbi system,,not sure which yet but probably a RBK44.
One question I have is about hooking up the satellites.  I believe a satellite can be connected to the router wirelessly but can it also be connected via an ethernet cable?
Then next, I'm currently using a Netgear DGND4000-N750  DSL modem/Router.   I't seems to be fine.  I'd like to keep using it but just for the modem.  I don't think it would be of any other use,,(would it?),,, does anyone know how to configure it to work that way with the Orbi?
THANKS!
1 Reply
