NonPlusUltra
Dec 09, 2020Tutor
Orbi I have lost the ability to test speed
Hello, I'm still fairly new to the Orbi mesh system and I'm so far satisfied with it. One issue is puzzling me: 1. I've lost the ability to test the speed of my connection from it. I can still te...
- Dec 11, 2020
Thank you. I will wait, I have to many devices to make it worth having the capability to test speed directly from the Orbi.
Dec 09, 2020Guru - Experienced User
You could try a factory reset on the router?
What modem/gateway is it connected to?
I usually don't recommend people use the built in speedtest anyway because its not the most accurate. It doesn't always pick the fastest server so can give you skewed results. It is nice for a handy quick test.
NonPlusUltra
Dec 09, 2020Tutor
I was hoping for a less harsh solution than factory reset as I have a a fairly complex setup that's hard to replicate, particularly manually configuring smart home devices to connect to the router/ap. It is connected to a Netgear CM1100 modem/router.
I understand the caveat of testing for speed directly from the orbi, but I'm curious that is not working as it is nice to have for a quick test check.
Thanks in advance,
- plemansDec 09, 2020Guru - Experienced User
Then I guess its up to you.
If it bothers you enough, try the reset. If it doesn't, then leave it and see if the next firmware update fixes it.
MIght not be a bad idea to make a backup configuration. That way if you did do a reset, you can always try reinstalling with the backup.
- MarcoNSDec 10, 2020AspirantI tried the backup method, you will still run into the same issue. You have to factory reset and reconnect all devices one by one, that seemed to fix the issue but it was a pain reconnecting everything.
- NonPlusUltraDec 11, 2020Tutor
