NonPlusUltra
Dec 09, 2020Tutor
Orbi I have lost the ability to test speed
Hello, I'm still fairly new to the Orbi mesh system and I'm so far satisfied with it. One issue is puzzling me: 1. I've lost the ability to test the speed of my connection from it. I can still te...
- Dec 11, 2020
Thank you. I will wait, I have to many devices to make it worth having the capability to test speed directly from the Orbi.
CrimpOn
Dec 09, 2020Guru - Experienced User
NonPlusUltra wrote:Hello, I'm still fairly new to the Orbi mesh system and I'm so far satisfied with it. One issue is puzzling me:
1. I've lost the ability to test the speed of my connection from it. I can still test it from the connected devices, but not directly from the menu in the Orbi. I get a "Connection Failed" message (If the problem persists, try rebooting your router).
Does Speedtest work correctly from user devices? i.e. the only Speedtest that fails is from the Orbi web interface?
