jolo2
May 13, 2018Star
Orbi: I need to switch off wireless radios at night
I have an Orbi system, RBR50/RBK50. I am increasingly aware of research that makes a good case for health risks for children from wifi systems, even if they operate within legal limits (e.g. https:/...
May 13, 2018Guru - Experienced User
You can reduce the power out put from the radios...
jolo2
May 13, 2018Star
Thanks, but can I do that on a schedule? It needs to work well when it's in use.
- FURRYe38May 13, 2018Guru - Experienced User
Unfortunately theres no scheduling of wifi on these systems. So you can either lower the power or disable the radios however it would have to be done manually.
