jolo2
May 13, 2018Star
Orbi: I need to switch off wireless radios at night
I have an Orbi system, RBR50/RBK50. I am increasingly aware of research that makes a good case for health risks for children from wifi systems, even if they operate within legal limits (e.g. https:/...
djc6
May 14, 2018Luminary
Have you considered an electrical outlet timer?
- StallionoAug 25, 2018Guide
Regarding the electrical timers suggested above.....
This is what I have done as well. However, these routers and satellites should have the capability to enable/disable wireless radios at times as desired by the end user. This feature set (as well as many others) is avaible on numerous other routers / WAPs at substantially lower price points.
Orbi stated this funtonality will be implemented in a future firmware update. Monthes later Orbi & STILL WAITING.... I currently don't recommend these because of limited customization and unfillfilled promises. The performance as a dumb box of hardware that delivers high speeds and relibility is great, but the price should command customization at least as much as competitors at a fraction of the price.
- tsigAug 25, 2018Luminary
So you bought the product fully aware of its "limitations", and are now complaining about those "limitations"?
- StallionoAug 25, 2018Guidetsig... your sarcastic antagonistic responses are so refreshing.... said no one ever. You must be a wonderful person. A common vain in your responses is irascibility.
Yes. I was aware of said limitation along with said company response to include this ubiquitous feature set available in seemingly every other router. And yes I’m complaining because the company’s pledge for said functionality has not been realized. Peace.
