eriklindgren
Mar 24, 2020Tutor
Orbi i NOT a mesh system!
My Orbi system: RBR50 +2 RBS50 +1 outdoor satelite RBS50Y Have had plenty of problems with wifi during the years, big house with concrete walls. The only system that have worked without problems ...
- Mar 24, 2020
eriklindgren wrote:Can I inperpret this answer as that the Orbi is NOT a mesh system but a hub-and-spoke system?
Absolutely. That is what I said. In the sense that you define, it is NOT. It is very definitely a hub and spoke system.
Mar 24, 2020Guru - Experienced User
Yes, the 3rd 5Ghz radio which supports up to 1733Mbps connection rates between the RBR and RBS is the wireless backhaul that is the communication radio between the RBR and RBS. The RBS can be wired as well to communication both client and RBS traffic over the LAN cable connection.
Concrete and steel will impact any 5Ghz radio propagation and operation.
eriklindgren
Mar 24, 2020Tutor
- Retired_MemberMar 24, 2020
only after you explain the differences.
- CrimpOnMar 24, 2020Guru - Experienced User
