eriklindgren
Mar 24, 2020Tutor
Orbi i NOT a mesh system!
My Orbi system: RBR50 +2 RBS50 +1 outdoor satelite RBS50Y Have had plenty of problems with wifi during the years, big house with concrete walls. The only system that have worked without problems ...
- Mar 24, 2020
eriklindgren wrote:Can I inperpret this answer as that the Orbi is NOT a mesh system but a hub-and-spoke system?
Absolutely. That is what I said. In the sense that you define, it is NOT. It is very definitely a hub and spoke system.
eriklindgren
Mar 24, 2020Tutor
CrimpOn
Mar 24, 2020Guru - Experienced User
