eriklindgren
Mar 24, 2020Tutor
Orbi i NOT a mesh system!
My Orbi system: RBR50 +2 RBS50 +1 outdoor satelite RBS50Y Have had plenty of problems with wifi during the years, big house with concrete walls. The only system that have worked without problems ...
- Mar 24, 2020
eriklindgren wrote:Can I inperpret this answer as that the Orbi is NOT a mesh system but a hub-and-spoke system?
Absolutely. That is what I said. In the sense that you define, it is NOT. It is very definitely a hub and spoke system.
eriklindgren
Mar 24, 2020Tutor
In my experience, marketing terms are not nearly as precise as one might hope. Is Netgear's Orbi a "mesh" in the sense that every device can be configured to connect to the internet and every device establishes links to every other device? NO. All of the promotional material from Netgear shows clearly how the "router" is connected to the internet feed and the "satellites" are connected to the router in a star or "Daisy Chain" manner. There is nothing deceptive about the description of what it is. I certainly knew going in what I was purchasing.
In a mesh network satellites communicate with each other and does not have to go through the router. That is the whole point with a mesh network.
Retired_Member
Mar 24, 2020
eriklindgren wrote:In my experience, marketing terms are not nearly as precise as one might hope. Is Netgear's Orbi a "mesh" in the sense that every device can be configured to connect to the internet and every device establishes links to every other device? NO. All of the promotional material from Netgear shows clearly how the "router" is connected to the internet feed and the "satellites" are connected to the router in a star or "Daisy Chain" manner. There is nothing deceptive about the description of what it is. I certainly knew going in what I was purchasing.
so when are you going to get a true mesh system?
