MaxLee2220
Feb 20, 2019Aspirant
Orbi in AP Mode. Can’t find the admin screen in the .com or net or use the Orbi app
Placed the Orbi in AP mode. After hitting apply I can’t log back into the admin .com or .net screen. I restarted the computer and all. And the Orbi app doesn’t pick up the Orbi on WiFi. The WiFi se...
Feb 20, 2019Guru - Experienced User
What FW is currently loaded?
Look at your hosts connected clients list. See if the Orbi IP address appears there. Can you access this IP address in a PC and web browser?
Is the LAN cable connected to the WAN port of the Orbi Base unit with the main host router?
Make sure your devices are connecting to the Wifi or LAN ports on the Orbi system and not a different wifi source.
And the Orbi app doesn’t pick up the Orbi on WiFi. The WiFi seems to be working just fine. The satellite doesn’t seem to be helping the modem. And can’t check any settings.
I have reseted the system and it will work on modem not AP. Don’t know what to do.
