MaxLee2220
Feb 20, 2019Aspirant
Orbi in AP Mode. Can’t find the admin screen in the .com or net or use the Orbi app
Placed the Orbi in AP mode. After hitting apply I can’t log back into the admin .com or .net screen. I restarted the computer and all. And the Orbi app doesn’t pick up the Orbi on WiFi. The WiFi se...
MaxLee2220
I have only tried to log on to orbilogon.com/.net from the computer (wireless on the orbi WiFi). Worked before I put the orbi on AP. Now it won’t find it.
I tried to login with the 10. Website and 192. One but zero results.
Feb 20, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem or router the NG router is connected too?
Try a reboot of the ISP modem or main host router then power OFF The Orbi for 10 seconds then back ON.
Check to see that your devices are getting an IP address.
- MaxLee2220Feb 20, 2019AspirantArris bgw210,
