CoreyOLi
Oct 13, 2020Aspirant
Orbi in AP mode, no longer able to access admin interface..
Well, I came here to post my issue and found I posted it a while ago, I still cannot get AP mode to work properly.. Here's the original post (I'm unable to reply on that post) Good evening eve...
CoreyOLi
192.168.1.50 - .90
The problem is, I can't get into the device to make any changes at this point, I'm really trying to avoid another reset as wireless devices are working properly and I don't want to take the network down if I can avoid it.
Thanks,
Oct 13, 2020Guru - Experienced User
Here is what I do, Factory reset the RBR while disconnected from any internet service. No WAN connection. YOu can setup the RBR with out the WAN port.
Once your back in and past the setup wizard. I setup the wifi SSID Name and PW. I disable Daisy Chain, Set 40Mhz only. Once all set here, go in and set AP mode. I set static IP address on my RBR, set gateway and DNS. Be sure gateway is the IP address of your host router. Once you have the Static configured, apply the setting. The RBR should reboot. After it's rebooted, connect it's WAN port to the host router. You should be able to access the RBRs web page at the Static IP address you set on it thru the host routers network or the switch you use.
How mines connected and configured.
- gr8shoOct 14, 2020VirtuosoHello.
This discussion makes my head hurt. If the Orbi is simply in AP mode to begin with, what purpose does static anything provide to the home network since the routing function is being handled upstream anyway?
And FWIW, my RBK50 is running in AP mode and I can access it just fine including admin function.
