Swickey999999
Dec 29, 2017Aspirant
ORBI IN AP MODE
Hello. I have the current update on my Orbi, but still cannot get AP mode to work.. Does anyone have any suggestions? I’m using a Rogers Wi-Fi modem, but have disabled the wifi capabilities of ...
TheEther
Dec 30, 2017Guru
There's not much that can go wrong. You go to ADVANCED > Advanced Setup > Router/AP Mode and enable AP mode. What are you observing?
Strictly speaking, you don't have to disable Wi-Fi on your Rogers modem when using the Orbi in AP mode. If you can put some distance between the Rogers box and Orbi and then you can blanket your house with Wi-Fi. Of course, this only makes sense if the Orbi can't cover the house on its own.
