Swickey999999
Dec 29, 2017Aspirant
ORBI IN AP MODE
Hello. I have the current update on my Orbi, but still cannot get AP mode to work.. Does anyone have any suggestions? I’m using a Rogers Wi-Fi modem, but have disabled the wifi capabilities of ...
Swickey999999
Dec 30, 2017Aspirant
I know! I did that.... once I select AP mode and wait for it to change, I can’t log into orbi login.com or orbilogin.net.
No devices are able to connect as well.....so I have to reset orbi to factory settings and leave it in router mode.
godspeed
Dec 30, 2017Apprentice
Is the Rogers Router/Modem handling DHCP?
Did you connect an ethernet cable from the Rogers Router/Modem to the WAN connection of the Orbi Router?
If both of those are "Yes", then you should be able to look at the mgmt page of the Rogers device and see what IP address is being assigned to the Orbi Router.
Once you have that, you can use the ip address, rather than the orbilogin.com to get to the Orbi mgmt page.
- Swickey999999Dec 31, 2017AspirantYes I did try that... page never loads
