rjk13230's avatar
Jan 23, 2021
Orbi in AP Mode
I've been successfully running an Orbi WiFi mesh for about 18 months. I have an RBR50, RBS50, RBS20, and quite a few IOT devices. I decided to install a dedicated pfSense firewall to give me more cap...
  • FURRYe38's avatar
    Yes, that would be it. The top ring LED detects and responds to WAN port connections only in AP or Router mode.
    Glad you found it. Please mark your thread as solved so others will know.
    Enjoy.
    rjk13230 wrote:
    I think I found the answer, the Orbi must have the WAN port connected to the router.
