smudgedj's avatar
Aug 07, 2018
Orbi in brazil
Anyone know how to get it working on Vivo in Brazil?
I’ve used the PPPoE cliente@cliente with password cliente but having no luck accessing the internet via the modem. I’m using the units in AP mode at the moment.
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
    • smudgedj's avatar
      smudgedj
      Tutor
      I’m doing no 3 at the moment and I’ll give no2 a go tomorrow morning.
      Many thanks for the quick reply.
