SDJ
Mar 03, 2017Tutor
Orbi in Malaysia
We've just swapped our crappy ISP provided router for an Orbi system, but cannot get it to broadcast internet. It runs and we can connect to its wifi, but I think the ISP's here use a particular conf...
genobkk
Mar 03, 2017Star
works fine in Thailand on fiber but I connect Orbi to ISP router turn off wifi and connect everything to the Orbi
SDJ
Mar 05, 2017Tutor
Thanks for your response genobkk. This is the setup that we currently have with an Airport Time Capsule, and it works fine. But replacing the Time Capsule with the Orbi base station doesn't seem to work. I've done some digging and found a statement that 'replacement routers in Malaysia must support VLAN tagging' but I was hopiong that by running the Orbi in series with the existing router but disabling the wireless then I'd be able to get round it.
