SDJ
Mar 03, 2017Tutor
Orbi in Malaysia
We've just swapped our crappy ISP provided router for an Orbi system, but cannot get it to broadcast internet. It runs and we can connect to its wifi, but I think the ISP's here use a particular conf...
Dopa
Jan 11, 2018Aspirant
I am having trouble connecting the Orbi to Tm Unifi as well.
I tried Melvin’s github link but it isn’t loading. Any have a working link for me?
Any help you can give me would be much appreciated.
melvinchng
Jan 11, 2018Apprentice
Link is working perfectly fine. Please try again.
- DopaJan 11, 2018AspirantYep, I edited the post but it obviously edit did not go through
On phone and it just showed an photo. Eventually figured out to click on the hamburger to bring up the menu. 🤦🏻♀️
So step 8A is where I fell down. No VLAN listed on the advanced > advanced settings
On version 1.xx, so maybe need to update which is one thing I didn’t do as only found this thread while I was trying to set up so connected to internet to DL.
Will download the update then try again.
Thanks Melvin - PhilippeGJan 19, 2018AspirantManaged to make it worked with Unifi. Thanks a lot.
- SpanketteFeb 27, 2018Aspirant
Hi, dunno if its the right thread for this but if i bought a US set Orbi, can it be use in Malaysia?
- melvinchngFeb 27, 2018ApprenticeYes. Only difference should be the plug. But it can take in 110-240V.
Thanks for the quick reply Melvin. Appreciate it.
