SDJ
Mar 03, 2017Tutor
Orbi in Malaysia
We've just swapped our crappy ISP provided router for an Orbi system, but cannot get it to broadcast internet. It runs and we can connect to its wifi, but I think the ISP's here use a particular conf...
kmchooi
Oct 12, 2018Aspirant
Hi, Pls see my respond below. Hope to have more guidance from team to ratify the problem and learn together. Thanks!
1. Are you able to get 500Mbps via a wired connection while running a speed test?
- No, both Wifi & wired connection max speed cap at ~90Mbps
2. Are you connected to 2.4Ghz or 5Ghz? You can check from the network status in your device
- My configuration is Auto. i.e. both 2.4Ghz & 5Ghz enabled. I used my iphone which assiged to 5Ghz but result is the same.
3. Are you conducting a speed test via mobile phone/laptop/desktop?
- I tried iphone and desktop (with Gigabyte lan port and Cat6 network cable connection to my router)
4. How old is your device?
- I bought my set in June'18 running with latest firmware.
h2
Oct 12, 2018Tutor
Hello ,
Try changing your Ethernet cable , preferably a Cat6 . Thereafter , do a speedtest with your device directly connected to any of the router’s ports .
Somehow, speedtest done on QOS from within the router itself is not accurate.
Hope this helps.
Hope this helps.
