SDJ
Mar 03, 2017Tutor
Orbi in Malaysia
We've just swapped our crappy ISP provided router for an Orbi system, but cannot get it to broadcast internet. It runs and we can connect to its wifi, but I think the ISP's here use a particular conf...
melvinchng
Oct 12, 2018Apprentice
1. Are you able to get 500Mbps via a wired connection while running a speed test?
- No, both Wifi & wired connection max speed cap at ~90Mbps; My experience tells me that there is a switch somewhere in between. Can you confirm if you have a networking switch?
3. Are you conducting a speed test via mobile phone/laptop/desktop?
- I tried iphone and desktop (with Gigabyte lan port and Cat6 network cable connection to my router); Does your desktop/laptop support Gigibit connections?
4. How old is your device?
- I bought my set in June'18 running with latest firmware; I meant to ask your laptop/desktop :D
Olé
Oct 19, 2018Aspirant
Hi, does anyone have a problem connecting to Astro PVR? My internet works fine with the router but I can't seem to connect my Astro to the router. But I have no problem connecting to Astro using my old, TM-provided Dlink DIR-850L. Help?
- oklah26Nov 17, 2018Aspirant
Hi,
Just bought my AC3000 yesterday, followed Melvin's setup with latest firmware 2.2.1.210, all was good (i setup it with LAN cable)... until when i plug in the ethernet cable trying to connect to the internet, it gave me an error from the TM saying router setup has got problem. Initially i thought is my TM ID and pwd, but i verified with TM, it seems to be correct. Anybody has any clue? I visited twice on Melvin's instruction, and pretty much followed exactly what it was stated... (** Even on the Home Basic page, the "Internet" status is displayed as "GOOD"... yet, it cannot go thru TM.. :(
Any help would be appreciated... Thanks. !
- melvinchngNov 17, 2018Apprentice
Streamyx or Unifi?
UNIFI... sorry.. forgot to mention.
- unknownhostFeb 08, 2019Aspirant
Hey there, I am facing the same issue. Not sure if there is a workaround to connect to Astro PVR wirelessly.
