evilhomerclone
Mar 06, 2020Aspirant
Orbi in Router mode continues to stop outgoing WAN connections
So i've had my Orbi RBK23 kit for sometime now, but from the beginning I have been using it in AP mode while being connected to my Fios Quantium Router. Things were going ok but I realize in AP mode...
CrimpOn
Mar 06, 2020Guru - Experienced User
evilhomerclone wrote:To resolve it, all I have to do is log into the Orbi Router and click "Test" within the Internet section, the Orbi does it's thing and walla the WWW is back.
Could you please be more specific about "Test within the internet section"? (Perhaps a screen shot?)
Perhaps I am too literal, but I have looked at the Orbi web interface, the Basic Tab and the Advanced Tab. The only "Test" I find is the Advanced Tab, Setup, Speed Test.
I would consider disabling Disney Circle temporarily to see if that makes any difference.
evilhomerclone
Mar 07, 2020Aspirant
When you log into Orbi router, from the homepage click on "Internet", takes you to "Internet Setup" menu and right at top, you will see "Test"
