Delany100
Apr 15, 2019Follower
Orbi in wired backlog has a few serious bugs - any i
Well, this is rich, I can't even select the model which is Orbi RBR50 (the three pack that you get at Costco).
I got the system set up and originally I was using wireless backhaul for everythin...
ekhalil
Apr 16, 2019Master
Delany100 wrote:
I decided to change it to a wired backhaul (already had the cable upstairs) and the light on the Orbi app went to red and wouldn't connect at all. So, I moved the satellite right next to the router, plugged it in and all was good (green across the board and wired backhaul). I then moved it back to it's original location. This is where things go bad.
The fact that when changing the cable to a shorter one the wired backhaul worked, shows that the cable is bad. Is it possible to troubleshoot the cable?
