Spirit
Aug 14, 2019Tutor
Orbi initial setup
I am new to Orbi and Netgear. I was having trouble setting up my new Orbi router and satellites - first time I have ever done something like this. So I typed "Orbi Phone Support" into Google and thi...
Aug 14, 2019Guru - Experienced User
Ya this is not official NG site.
What kind of information did you give them? Hopefully just ur name and maybe address. Put that number on a blocked caller list if you have that kind of phone support.
Spirit
Aug 14, 2019Tutor
i gave him my name, email and phone number.
Then he took remote access of my PC and told me that I had something called an alaurean (bug) on my PC.
He then tried to sell me some software. It was only at that point that I realized it wasn't Netgear.
My biggest concern is that my Password Manager was open on my device (I am such an idiot).
I have changed the master password and some ket passwords (banks, etc) and thankfully all seems ok
at this moment. The "orbi" site that I went on is so info intensive that it is hard to believe that this is a scam
but I assume it is.
I did a reverse phone lookup and the number also points to other router makers like asus and linksys.
Who are these people and what do they really want?
- FURRYe38Aug 14, 2019Guru - Experienced User
Lordy. :smileyfrustrated:
I recommend changing PWs on everything.
I would remove any odd programs seen on your PC thru the Control Panel, add/remove programs section.
Run a virus scan on your PC. Download MalWare Bytes program and do another scan of your PC for malware.
There just scammers trying to get you to pay them for nothing. Look at youtube for scammers or scammers getting caught. There out there trying to put crap on your PC or lock ur PC out and then some times will hold the PC as ransom until you pay. Offical NG will never do this with users unless there is a high level support ticket involved and only done thru NG official support lines.
Next time, contact NG support or check with official router forums to see what is officially supported and what sites maybe bad.
Good Luck.
