dsmith611
Apr 06, 2020Aspirant
Orbi Installation with rented Spectrum Modem/Router
Hi - I currently have a rented modem/router from Spectrum (Los Angeles - 90026). Technicolor (TC8715D). I also use Apple Airport's. (all dated I know). I want to purchase an Orbi Wifi Mesh Ne...
ekhalil
Apr 06, 2020Master
dsmith611 wrote:.......
A) Do I still need a router/modem after I buy the Orbi AC3000 (RBK50).
- If yes - do you recommend I stop renting mine from Spectrum and purchase a new one?
- If yes - any recommendations on what I need to complete my set up?
You still need a modem that has a coax cable interface that your ISP provides. The existing router will do, but if there is a simpler modem with no routing nor wifi capabilities that will be even better.
dsmith611 wrote:........
My hosue is 3 stories. is the 2 pack enough?
It depends on the area of the floors, the building material and if you have dead spots in the house. Generally 2-pack AC3000 nodes will be enough up to 4500 sq ft. If you have large floors and metal/cement building material then I would recommend one unit per floor.
dsmith611
Thank you so much. For simplicity and efficiency, is there a Netgear Modem you recommend?
- ekhalilApr 06, 2020Master
dsmith611 wrote:Thank you so much. For simplicity and efficiency, is there a Netgear Modem you recommend?
If you're not using the router for anything else like telephony or TV, then it's enough to have a MoCa adapter like Netgear MC1001.
https://www.netgear.com/images/pdf/NETGEAR-MCA1001v2-D-05092014-2.pdf
- dsmith611Apr 23, 2020Aspirant
Thank you! I do use the router for my Apple TV & wireless calling. So I need something to replace my rented modem/router that will support Spectrum (Los Angles, CA 90026) that will support my orbi mesh system, apple TV, etc.
