Wamphyri
Jun 04, 2019Aspirant
Orbi Interface Logging
Hi, I'm having an issue with connection stability between my Orbi and my Vodafone Modem. I was wondering if there was any interface level logging that can be enabled on the WAN port of the orbi? ...
Jun 04, 2019Guru - Experienced User
Check the logs under Advanced tab/Administration to see if anything maybe listed here.
