Wamphyri
Jun 04, 2019Aspirant
Orbi Interface Logging
Hi, I'm having an issue with connection stability between my Orbi and my Vodafone Modem. I was wondering if there was any interface level logging that can be enabled on the WAN port of the orbi? ...
Wamphyri
Hi,
Thanks for the response. Yeah thats great when you say "not too much time" how long is that? as the issue i have is intermittant it would be good to leave it running until it happens and then look at the interface logs so it would be great if the file auto rolled over then i can just look at the one(s) nearest the incidents. I can stick a 1TB drive on there to make sure i don't have to worry about space too.
thanks for the assist.
CrimpOn
Jun 04, 2019Guru - Experienced User
Wamphyri wrote:Thanks for the response. Yeah thats great when you say "not too much time" how long is that?
Honestly, I have no idea how quickly the debug file grows, or even where it is stored. "System memory" might mean "memory" of which my Orbi has 495MB and is using 137MB. Or, it could be "flash memory", of which my Orbi has 4096MB and is using 2945MB. When I did a couple of minutes, the zip file was just under 2MB.
I will look around for a USB drive and see what happens when I select writing to that. (Hmmmm. There is an enduring complaint that Netgear's "Readyshare" was promised for the USB port, but has never materialized. That's probably different from a debug process. Will be interesting to see what happens.)
- WamphyriJun 04, 2019Aspirant
Hi, Apologies I just realised I missed a comma in the "Yeah thats great, when you say "not too much time" how long is that?" which slightly changes the tone of the sentance (I didn't mean to appear rude, I'm genuinely thnakful for your response :) )
I'll give it all a go tonight when I can have time to play around with it. (and mostl likely suffer another incident)
Thanks Again. Really appreciated
- CrimpOnJun 04, 2019Guru - Experienced User
Well, THAT was interesting. Only the LAN and WAN captures went on the USB drive. The rest of the debug info got downloaded to my computer without the WAN and LAN captures.
I had another thought. The "Traffic Meter" (such as it is), shows an average days traffic for me to be between 3GB and 6GB. So, a decent size USB drive will easily hold hours and hours of traffic. Parsing it with Wireshark... now that's another matter entirely!
- WamphyriJun 10, 2019Aspirant
Turns out it doen't like my 1 tb Drive :( i've now dug a bit deeper and noticed that the disconnects last between 4:52 and 4:59 in length which is clearly an interface reset time a it requires no interaction form me for resolution.. as i have a telnet connection now i'm trying to find the logs from that.
- CrimpOnJun 10, 2019Guru - Experienced User
Wow. A 1TB USB stick! I don't think Orbi likes USB "drives".
