LMF777
Mar 08, 2019Aspirant
ORBI Intermittent internet drops on WIFI devices only if Circle is enabled
I have the last firmware installed and everything I have seen within the Netgear forums is Netgear is saying issues have been resolved with the latest Firmware. I totally disagree. Current firmware ...
ekhalil
Mar 08, 2019Master
LMF777 wrote:
.......... The renew IP fixes it almost instantly but a pain having to this 5 or more time every single day. .............
- Do you do renew IP on the devices or on the WAN port?
- Do you see the same issue with wired as well as wireless devices?
- What type of devices do you have attached to your network?
- What wired devices do you have attached to Orbi nodes?
Mar 08, 2019Guru - Experienced User
- Do you do rener IP on the devices or on the WAN port?
