Amirlit
Apr 05, 2021Guide
Orbi Internal Server Error 500 RB40
Recently upgraded to Firmware V2.6.2.104 Now looks as if I'm getting Error 500 going to Access Controls. None of my satellites are showing up properly. Is thier either a new firmware coming ...
- Apr 13, 2021
I was able to solve the problem by reapplying (manually) the same firmware. Reseting from scratch probably would of also solved the problem but that is a SERIOUS pain in the ass. So I highly suggest the first thing you do, is simply try to reapply the same firmware to the devices. Then if it does not work, reset the device and/or buy a new device :)
Amir
Apr 05, 2021Guru - Experienced User
Try a factory reset and setup from scratch.
Be sure to clear out all browser caches as well. Try a different browser as well after the reset.
