Amirlit
Apr 05, 2021Guide
Orbi Internal Server Error 500 RB40
Recently upgraded to Firmware V2.6.2.104 Now looks as if I'm getting Error 500 going to Access Controls. None of my satellites are showing up properly. Is thier either a new firmware coming ...
- Apr 13, 2021
I was able to solve the problem by reapplying (manually) the same firmware. Reseting from scratch probably would of also solved the problem but that is a SERIOUS pain in the ass. So I highly suggest the first thing you do, is simply try to reapply the same firmware to the devices. Then if it does not work, reset the device and/or buy a new device :)
Amir
Amirlit
Apr 13, 2021Guide
Amir
Apr 13, 2021Guru - Experienced User
Or try a factory reset and setup from scrach. Be sure to save off a backup configuration file for safe keeping. This saves time when or IF a reset is needed.
Enjoy. :smileywink:
Amirlit wrote:I was able to solve the problem by reapplying (manually) the same firmware. Reseting from scratch probably would of also solved the problem but that is a SERIOUS pain in the ass. So I highly suggest the first thing you do, is simply try to reapply the same firmware to the devices. Then if it does not work, reset the device and/or buy a new device :)
Amir
