rawb1's avatar
rawb1
Orbi Internet access through VPN but NOT VPN passthrough.
I can log into my remote network where the Orbi is running, and access local shares and NAS equipment. I'd like to be able to then access the internet out from the remote Orbi. There is no need fo...
  • CrimpOn's avatar
    CrimpOn
    Nov 19, 2021
    Thanks for showing the images. I see this is a tap connection, a 'layer 2' type.
    https://en.wikipedia.org/wiki/TUN/TAP
    I admit to ignorance about how a computer decides which gateway to use when accessing the internet, the gateway on the primary adapter or the gateway on the VPN adapter. (I am not being much help.)
    My first thought is to change to a tun connection on port 12973.
