Jeremy042363
Oct 01, 2018Follower
Orbi Internet connection issues
My Obrbi app is telling me the Internet is off-line however, I can send emails but, I can't download apps to mobile devices.
My system is in the UK using a BT modem - I bypass Orbi and select t...
Oct 01, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
