MaxwellStyler's avatar
Mar 19, 2020
Orbi Internet Freezes Every 30 Seconds
With the Orbi RBK40 (i think) the guest wifi doesnt freeze every 30 seconds, just the main one, Ive tried everything, I cant figure out why its happening.
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
