Disgruntledorbi
Feb 05, 2022Aspirant
Orbi internet port broke?
For the most part our Internet has been working just fine as it was all day yesterday. We sat down to stream a movie and the Internet was out. I called the ISP and everything is fine on the modem side. Even plugged a laptop directly into the modem and it works. Using the same ethernet cable and I’ve tried a few the router does not receive an Internet signal. I haven’t touched any of the Settings in a long time and I have no idea if it did a firmware update yesterday or not. I usually keep it on the latest firmware and it has not told me it needed to update in a long time.
- DisgruntledorbiAspirantIs this a broken port or did something in the settings or firmware change? Also tried factory resetting to no avail.
what modem/gateway do you have ?
- DisgruntledorbiAspirantI’m not sure of the modem. Whatever the ISP gave me. So short term I solved it with a factory reset actually, however, I’m not sure what caused the router service to stop randomly. I’m on the latest firmware and have had odd blackouts in the past.
