DerekV
Jun 12, 2018Guide
Orbi Internet Speed Test 1/2 of my R9000
I bought an RBK53 at Costco today due to issues I've been having in my house with disconnects and my R9000. Setup with the app did not go smoothly and I reverted to setting up via the browser. I upda...
Jun 12, 2018Guru - Experienced User
Is this speed testing of the speedtest app on the router or with a wireless device connected to the router?
What are the wired speeds with a wired PC connected to the router?
If you have 1Gb ISP service, it's recommended to do a factory reset of the router, then set up from scratch and this time, do not enable the onboard speedtest, traffic meter or access controls as these will slow the speed down when on a 1Gb ISP service.
- DerekVJun 12, 2018Guide
I did the speedtest through the Orbi admin, just like the R9000 admin. I will, yet again, restore defaults and start from scratch. And this time I won't do the speedtest.
Wasn't this supposed to be fixed in the most recent firmware? Is beta firmware available to test?
- FURRYe38Jun 12, 2018Guru - Experienced User
You can look at the release notes to see if it was fixed or not.
Current FW is v2.1.4.16 can be found here:
