Magpaca
Jan 07, 2018Follower
Orbi iOS app crashes on open
I was able to get the Orbi and satelitte configured with the iOS app, but it began crashing on startup a couple of hours later. I have tried opening on multiple devices and uninstall and reinstalling...
jtinnova
Jan 16, 2018Aspirant
I had the same problem. I had the Orbi network up and running in less than 15 minutes (RBK50 and one RBS50) last night. Everything was working fine. Then I tried to look at the settings in the app today and as soon as it would get to the login page. BAM. gone. I deleted the app and reloaded. Same thing. I kept trying. Then after about three or four mor attempts, the app posted a splash screen that said IP address was changed to 10.10.0 to avoid conflict with Internet Service Provider (or something to that effect). Anyway the 10.10.1.x defalut address space that it used when I created the networ I think is the default for my FiOS router that the RBK50 Orbi router is plugged into. So it worked but I think it was conflicting with the FiOS router and that was causing the Orbi iOS ap to crash as soon as it tried to log into the Orbi router. Hope this helps.
jtinnova
Mar 08, 2018Aspirant
EVERYONE!
Check your IP address space to see if it conflicts with your internet router. Orbi defaults to 10.10.1.xxx
This is the same default address range the FiOS router is set to. Once I changed Orbi to 10.10.2.xxx and solved the conflict, the app stopped crashing.
- bbinetteMar 08, 2018Aspirant
OK - but why would this start happening just recently?
And since you have an Orbi - while I'm familiar with the settings, I'm not that familiar - how do I make this change? Can you point me exactly where to do this?
Thanks in advance.
- jtinnovaMar 08, 2018Aspirant
Log into the router. Go to the Advanced tab. Expand the "Setup" menu on the left. Select "LAN Setup".
You should see IP Address set that as the address of your Orbi. Check the "Use Router as DHCP Server" in the box below. The Starting and Ending IP Adress should auto populate.
I mistakenly said it was my FioS router conflicting. It is actually my stupid DirecTV junk hardware in the 10.1.1.x space that was conflicting with the default Orbi addresses.
- FURRYe38Mar 08, 2018Guru - Experienced User
What Mfr and model # ISP modem do you have?
When setting up the Orbi router, the router will detect any conflicts in IP addressing and make a recommendation and change to something that doesn't confict...
jtinnovawrote:Log into the router. Go to the Advanced tab. Expand the "Setup" menu on the left. Select "LAN Setup".
- FarscapeMar 08, 2018GuideInstalled an Orbi Pro with 2 satellites several days ago and also installed the Orbi app on an iPhone X (iOS 11.2.6) with no issues.
Tried installing the app on an iPad Pro 9.7” this morning (latest iOS version) and the app crashes after login when it starts searching for the installed Orbi system. Also, tried deleting and reinstall, but still crashes.- FURRYe38Mar 08, 2018Guru - Experienced User
Whats the iOS version on the iPad?
Tried installing the app on an iPad Pro 9.7” this morning (latest iOS version) and the app crashes after login when it starts searching for the installed Orbi system. Also, tried deleting and reinstall, but still crashes.- FarscapeMar 08, 2018Guide
iPad Pro has 11.2.6.
Weird. Just opened it again (10 hours later) and it was on the initial page looking for the orbi system then "crashed". Opened the app again and it went to the login page. Signed in and now it is working. Now only if the Orbi Pro would stop giving me periodic grief.
