Buko
Oct 04, 2021Aspirant
Orbi iOS app not showing correct network mapping
Hello, i am facing some strange problem, as you can see on a photo there is my network setup showed on android and ios, but the way android shows is is correct. Why iOS app is not showing my 3rd ...
Oct 04, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
