JamesRichard
Sep 17, 2019Aspirant
orbi ip address 10.0.0.1
I'm trying to setup my new orbi router as my only router. But having trouble... When I first set it up the orbi, I connected it to my existing bt homehub router. Whilst the signal strength was su...
Sep 17, 2019Guru - Experienced User
Your modems have built in routers already. If you want to use the Orbi as a router, try one of the following:
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Reason that the Orbi is getting a 10.0.0.1 address is that the default IP address of 192.168.1.1 that Orbi normally uses is in conflict with one of the modems. Thus the Orbi changes to something that doesn't conflict with that IP address.
JamesRichard wrote:I'm trying to setup my new orbi router as my only router. But having trouble...
When I first set it up the orbi, I connected it to my existing bt homehub router. Whilst the signal strength was superb, issues arose when loading unsecured websites, and I understand this would be expected when ttying to use two routers connected in series. So I bought a separate netgear modem (DM200). When I connected the orbi to the new modem, the orbi decided it needed to change its IP address to 10.0.0.1, and no-longer accessed any websites at all.
I'm currently using the router in AP mode with the pre-existing bt homehub as the main router. But this is not what I want to do. Any suggestions gratefully received!
- JamesRichardSep 17, 2019AspirantThe Netgear DM200 modem doesn’t have a built-in router. I’ve set this modem to bridge mode. But my Orbi still sticks with the IP address 10.0.0.1. Surely the Orbi can’t be in conflict with a router in bridge mode (I sound confident but obviously don’t really know what I’m talking about!)?
- michaelkenwardSep 18, 2019Guru - Experienced User
JamesRichard wrote:
The Netgear DM200 modem doesn’t have a built-in router.It does have a modem by default. Do you mean that you have disabled it?
If so, remember to connect everything in the required order.
After you have disabled the modem bit of the DM200, turn it off, and then restart the whole network.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
I would also factory reset the Orbi before going through this process.
- FURRYe38Sep 18, 2019Guru - Experienced User
The DM seems to have a built in router as per it's user manual: Pg59
http://www.downloads.netgear.com/files/GDC/DM200/DM200_UM_EN.pdf
Are you sure the DM modem is in bridge mode?
If you factory reset the RBR and walk thru the set wizard with it connected to the modem, what IP address appears on the RBR after completing the setup wizard?
JamesRichard wrote:
The Netgear DM200 modem doesn’t have a built-in router. I’ve set this modem to bridge mode. But my Orbi still sticks with the IP address 10.0.0.1. Surely the Orbi can’t be in conflict with a router in bridge mode (I sound confident but obviously don’t really know what I’m talking about!)?- CrimpOnSep 18, 2019Guru - Experienced User
FURRYe38 wrote:The DM seems to have a built in router as per it's user manual: Pg59
Thanks for finding the manual. I jumped to the wrong conclusion when the back panel showed only one ethernet port.
