JamesRichard
Sep 17, 2019Aspirant
orbi ip address 10.0.0.1
I'm trying to setup my new orbi router as my only router. But having trouble... When I first set it up the orbi, I connected it to my existing bt homehub router. Whilst the signal strength was su...
JamesRichard
The Netgear DM200 modem doesn’t have a built-in router. I’ve set this modem to bridge mode. But my Orbi still sticks with the IP address 10.0.0.1. Surely the Orbi can’t be in conflict with a router in bridge mode (I sound confident but obviously don’t really know what I’m talking about!)?
michaelkenward
Sep 18, 2019Guru - Experienced User
It does have a modem by default. Do you mean that you have disabled it?
If so, remember to connect everything in the required order.
After you have disabled the modem bit of the DM200, turn it off, and then restart the whole network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
I would also factory reset the Orbi before going through this process.
