xtbe's avatar
xtbe
Guide
May 28, 2018
Orbi issue with sattelite
Hi,   I have an issue with one of the satellites. It gets connected but I don't have internet access via that one. I've placed it already close to the router to ensure I have connection and the b...
  • FURRYe38's avatar
    May 28, 2018
    Turn OFF the other working satellite and do a factory reset on the one non working satellite. Disable Daisy Chain on the router.
    Re-add the one non working satellite and get it re-connected. Check for the BLUE led on top. Connect a wireless device to this one satellite. Do you get any internet then?
    Can you connect to it's web page after it's re-added and set up and working?
    Check to see if it's connected on the routers connected clients page there and check for it's IP address.
    What is the distance between the satellites and the router?
    What FW version is currently loaded on the system?
