OrangeBlue
May 04, 2020Aspirant
Orbi Issues After Firmware Update
I updated the firmware on my RBR40 and RBS40 to latest version and they have become extremely unstable. The Orbi App periodically says it is not compatible with my router, which seems very odd. The RB...
May 04, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF The ISP Modem as well for 30 seconds then back on. Walk thru the setup wizard and be sure to write down all important information. Be sure not to enable Armor, Circle, Access Controls, QoS or Traffic Meter on the RBR.
OrangeBlue wrote:
I updated the firmware on my RBR40 and RBS40 to latest version and they have become extremely unstable. The Orbi App periodically says it is not compatible with my router, which seems very odd. The RBR40 is connected to a Netgear CM700 modem.
I tried re-installing the firmware upgrade and it didn’t help. Frequent dropping of internet connection and weird things like mobile browser pulling up what looks like a router management login rather than the website for the entered URL.
Any input would be appreciated.
- OrangeBlueMay 04, 2020AspirantThe satellite is connected via Ethernet. System was incredibly stable until I updated it.
- FURRYe38May 04, 2020Guru - Experienced User
Is the RBS connected directly to the RBR or connected to a switch? If a switch is in the mix, what is the mfr and model# of this switch?
Be sure Daisy Chain is disabled if you have the RBS connected via ethernet.
OrangeBlue wrote:
The satellite is connected via Ethernet. System was incredibly stable until I updated it.- OrangeBlueMay 04, 2020AspirantNo switch in between.
I turned off daisy chain, but no difference.
